Urgent issue in Builder option "Auto-save user configuration on exit"
Posted: Sun May 27, 2018 11:19 pm
I am encountering the following issue with the MegunoLink Builder:
when exiting the program created by builder, the values of all fields in the program are saved. So, when I reopen the program it reverts to the last used values. However, what I want/need is that each time the program is restarted it reverts to the default values that I have set when creating the program in MegunoLink. This is to ensure that values loaded by the program are consistent with default value of variables in my Arduino code.
When creating the program with builder, there is a checkbox called "auto-save user configuration on exit". However, the above behavior occurs no matter if I check or uncheck this option.
Is this a bug?
Is this a bug?
