I assume that the Interfacepanel wants the Arduino to communicate with the UI via the Serial port.
But how do I change that port to Serial2?
RoboBill
InterfacePanel com port
Nice one! The relevant documentation can be found here
https://www.megunolink.com/documentatio ... zer-class/
Another approach is to jump into the library code (I find github a great place to do this) and see if you can see the sort of functionality you're hunting. For example
https://github.com/Megunolink/MLP/blob/ ... acePanel.h
That link shows the interfacepanel header file. You can see under public it has Print &rDestination = Serial. That is inside the constructor and the default is Serial. In your guess, you correctly changed it to Serial2.
That was my first approach. But since I'm not a programmer, I had no clue what &rDestination = Serial really meant. But I did see how you did the XYPLOY stuff, so I figured you probably would do the same for interfacepanel.
Just got lucky
RoboBill
Just got lucky
RoboBill
