It is related to uninitialized pointers and variables, something the ESP32 compiler does not really like. Attached is the bottom part of the log file. Errors are at the bottom (as always,
I tried to post this is a bug, but I did not get confirmation it was sent. So trying again via the forum.
Arduino: 1.8.5 (Windows 10), Board: "SparkFun ESP32 Thing, 80MHz, 921600"
"C:\Users\ingma\AppData\Local\Temp\arduino_build_326767\libraries\MegunoLinkPro\utility\CommandDispatcherBase.cpp.o"
In file included from C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro\utility\CommandDispatcherBase.cpp:1:0:
C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro\utility\CommandDispatcherBase.h: In constructor 'MLP::CommandDispatcherBase::CommandDispatcherBase(MLP::CommandCallback*, uint8_t, MLP::VariableMap*, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro\utility\CommandDispatcherBase.h:26:19: error: 'MLP::CommandDispatcherBase::m_uMaxCommands' will be initialized after [-Werror=reorder]
const uint8_t m_uMaxCommands;
C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro\utility\CommandDispatcherBase.h:25:28: error: 'MLP::CommandCallback* const MLP::CommandDispatcherBase::m_pCommands' [-Werror=reorder]
CommandCallback *const m_pCommands;
C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro\utility\CommandDispatcherBase.cpp:7:1: error: when initialized here [-Werror=reorder]
CommandDispatcherBase::CommandDispatcherBase( CommandCallback *pCallbackBuffer, uint8_t uCallbackBufferLength, VariableMap *pVariableMapBuffer, uint8_t uVariableMapLength)
C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro\utility\CommandDispatcherBase.h:30:19: error: 'MLP::CommandDispatcherBase::m_uMaxVariables' will be initialized after [-Werror=reorder]
const uint8_t m_uMaxVariables;
C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro\utility\CommandDispatcherBase.h:29:24: error: 'MLP::VariableMap* const MLP::CommandDispatcherBase::m_pVariableMap' [-Werror=reorder]
VariableMap *const m_pVariableMap;
cc1plus.exe: some warnings being treated as errors
Using library arduinoFFT at version 1.2.3 in folder: C:\Program Files (x86)\Arduino\libraries\arduinoFFT
Using library MegunoLinkPro at version 1.9 in folder: C:\Program Files (x86)\Arduino\libraries\MegunoLinkPro
exit status 1
Error compiling for board SparkFun ESP32 Thing.
