First Project of Arduino + MegunoLink
Share your projects using MegunoLink Pro here!
wlasoi
Fri Nov 24, 2017 4:11 pm
Measuring capacitance
Interface
rsfoto
Fri Nov 24, 2017 8:06 pm
Thank you for posting a real life example :-) I just started with MegunoLink and the documentation is a bit confusing. Seeing a real life example as yours is much easier to understand it.
Is there a possibility to see the Interface on a bigger image ? Is is nearly impossible to see the details.
Is that a stand alone User Interface or id it using the MegunoLink software visalizer, etc.
Would it be possible to see the code to see how the communication or the data plotting works ?
Thanks and regards Rainer
Fri Nov 24, 2017 11:32 pm
Amazing interface! Nice work. It looks like there are 5 visualisers open. From top left going clockwise there is the Interface Panel, XYPlot, Monitor 1, Connection Manager (with two serial connections), and Monitor 2.
For a bit more help on plotting check out our Arduino examples. I've just recently made some videos trying to guide people through the use of them.
Installing the MegunoLink Arduino Library
https://www.youtube.com/watch?v=Ug9E8s6_usw
Launching the SetParameters Interface Panel Example
https://www.youtube.com/watch?v=vSeugsEmnJ8
A bit more detail on the SetParameters Interface Panel Example
https://www.youtube.com/watch?v=m929nM-1I7U
Let me know if this format of videos is helpful.
wlasoi
Sat Nov 25, 2017 3:02 pm
In the future, I will open both the source code and Schematic to see again, It is also prototype in the breadboard for urgent work. It takes only 2 days for this project. To remain on more work and also document.
This project is part of IV-Curve tracer for TR and Diode ..
https://www.4shared.com/s/f23G0oG0Iei
