So i'm having a bit of an issue trying to figure out how to change the forecolor and backcolors of my dynamic label or progression bar. Anyone out their can give me a hand?
my code is to read a pot and display the pot position. Then set a location for the motor to turn the pot to that location. I would like to display different colors to show what direction the motor is spinning and when it stops on the corresponding set location.
Here is my code. When I put the code from the example into my loop in an IF statement. My Arduion errors out with an " no matching function for call".
//serial interface button
int Loco = 0;
CommandHandler<> SerialCommandHandler; //serial comms
void Cmd_GetLoco(CommandParameter &Parameters)
Parameters.GetSource().print(F("Value of set location = "));// print text on serial bus
Parameters.GetSource().println(Loco);
void Cmd_SetLoco(CommandParameter &Parameters)
Loco=Parameters.NextParameterAsInteger(Loco);// needed for comms
InterfacePanel MyPanel;// interface panel
const int pot = A2;// open a var box for location bar
const int Adv = 2;// open a var box for advancing the motor
const int Stay = 3;// open a var box to stop movement
const int Ret = 4;// open a var box for retracting the motor
pinMode(Adv,OUTPUT);
pinMode(Stay,OUTPUT);
pinMode(Ret,OUTPUT);
SerialCommandHandler.AddCommand(F("SetLoco"), Cmd_SetLoco);// commands to read interface commands
SerialCommandHandler.AddCommand(F("GetLoco"), Cmd_GetLoco);//commands to read interface commands
//Progress bars
float DataValue = analogRead(pot);
Serial.println(Loco);
delay(250);
MyPanel.SetProgress(F("IPProgressBar1"), DataValue);
delay(250);
if (Loco == 0)
{MyPanel.SetText(F("Set"), "NO location Set.");}
if (Loco > 0)
{MyPanel.SetText(F("Set"), "Ready for Action.");}
//MyPanel.SetForeColor(F("Status"), "Red");
//MyPanel.SetBackColor(F("Status"), "Blue");
if (Loco > DataValue)
digitalWrite(Adv, HIGH);
digitalWrite(Stay, LOW);
digitalWrite(Ret, LOW);
MyPanel.SetText(F("Status"), "To Pin");
//MyPanel.SetForeColor(F("Status"), "Green");
if (Loco < DataValue)
digitalWrite(Adv, LOW);
digitalWrite(Ret, HIGH);
MyPanel.SetText(F("Status"), "From Pin");
//MyPanel.SetForeColor(F("Status"), "Blue");
if (Loco == DataValue)
digitalWrite(Stay, HIGH);
MyPanel.SetText(F("Status"), "Hold");
// command handler instruction
Changing colors
Hi, I just tested the colour properties here and it seemed to work. Can you capture the serial messages sent from your device in the monitor? Do they look like this:
{UI|SET|MyLabel.ForeColor=blue}
{UI|SET|MyLabel.ForeColor=red}
{UI|SET|MyLabel.ForeColor=green}
{UI|SET|MyLabel.ForeColor=black}
{UI|SET|MyLabel.BackColor=blue}
{UI|SET|MyLabel.BackColor=red}
{UI|SET|MyLabel.BackColor=green}
{UI|SET|MyLabel.BackColor=white}
Make sure that the name of your label is correct. In my case its "MyLabel".
Thanks for your input sir,
Their is no command on the Serial bus. The code is crashing in the compiler.
I notice when i type the words "SetForeColor" , this text does not change colors (orange) as it does when i type "SetNumber" or "Serial. print"
it's as if Ardurino ide does not recognize these commands.
can the forecolor and backcolor be changed on the progression bar? i would like it to change colors at a preset point during the progression. The example color changing does not work. with or without the F() code.
