Jerky time scale
Rod
Thu Feb 28, 2019 11:50 am
Probably simple but I can't find it.
During a data acquisition session, the time scale changes resolution. It might say 44:54:00 and then 44:58:000.
That extra 0 causes the entire graph to resize.
Is there a way to make the time plots work like an oscilloscope? I don't need time stamps, just a time scale.
Thanks.
Rod
Fri Mar 01, 2019 6:13 am
Hi Rod, can you please capture a log of the raw serial stream and we can replay it here to see the behavior.
Rod
Tue Mar 12, 2019 5:58 pm
Phil,
Sorry this reply took so long .... a dozen other projects.
Part of the problem is after suffering from the jerky time scale for two days, I wrote a bit more code, resized the graph, it went away, and I can't reproduce the problem.
We used to say "All's well that ends". It doesn't have to end well, it just has to end. In this case it did end well (for now). Many of these things seem to pop up at the most inopportune time.
All in all I'm very happy with your product and support. I've told my friends!
Rod
Wed Mar 13, 2019 5:02 am
Ha sometimes that's just how it goes.
