Multiple plots with the BMP280
Vanguard
Post by Vanguard » Fri Mar 16, 2018 10:58 am
Hello, I'm a novice with using the Arduino UNO and certainly with MegunoLINK.
Finally I have the BMP280 barometric pressure sensor working, also a nice plot with MegunoLink.
I now would like the pressure and the temperature in multiple plots, sending different data to different channels, with corresponding Y and X label.
I use as an example https://www.megunolink.com/documentatio ... ple-plots/,
but do not get it together.
Please advice.
Thank you, Jan Bouma
After a flashing brainwave I solved the problem.
It is working now super!
I didn't write the TimePlot xxxxx as a variable
