Gauge
Siderits
Mon Jul 09, 2018 1:20 am
Would anyone have some insight about why my Gauge is stuck?
I'm using the statement MyPanel.GetValue(F("MyGauge"), SensorValue); in the Loop section of the Arduino sketch, but the visualizer shows the following message: some ASCII characters and the sentence "doesn't exist in MyGauge".
The TimePlot works fine with the analogRead(0) which stores to the variable SensorValue.
Thanks!
Rich
Mon Jul 09, 2018 7:34 pm
Hi Rich, are you trying to "get" the value from your gauge or "set" the gauge to show a value? You're example shows a get.
Siderits
Tue Jul 10, 2018 12:41 am
Hi Phil:
I have a simple light sensor setup on a breadboard that is updating a TimePlot with no problem, but would like to have a gauge also reading the SensorValue from the photo-resistor.
I can set the gauge value with a statement like: MyPanel.SetNumber(F("MyGauge"), 42); but I can't figure out how to read the photo-resistor value thats coming in from int SensorValue = analogRead(0); and then have that number display on the gauge. There doesn't yet seem to be an example of a gauge script to follow and learn from.
Richard
Tue Jul 10, 2018 7:55 am
Hi Richard, so you would just go MyPanel.SetNumber(F("MyGauge"),analogRead(0)). or:
MyPanel.SetNumber(F("MyGauge"),SensorValue);
Does that make sense?
Tue Jul 10, 2018 8:19 am
Attached is an example which includes setting the gauge. The .ino files is the arduino program and the .mlpz file is a pre-made megunolink interface.
UpdatingInterfaceFromArduino.zip
(30.77 KiB) Downloaded 82 times
