Send Float to Interface Problem
mr4681
Thu Nov 20, 2014 6:14 pm
I notice that when I send floating value from Arduino to interface with SetNumber command. Value will be changed to integer and I lost the floating point.
I try to fix this problem by add new function in InterfacePanel.cpp by overload function. It work fine.
Please comment or suggest.
SVP
void InterfacePanel::SetNumber(const char * ControlName, float fValue, int decimal) // Added by SVP
SendControlHeader(ControlName, F("Value"));
Serial.print(fValue,decimal);
SendDataTail();
raescuin
Sat Nov 22, 2014 10:05 am
How do I set this up? I'm getting an error.. thanks
Tue Dec 02, 2014 5:06 pm
Nice find! I'll make sure I update the library with your added function.
