Extend amount of data that can be logged with Message
Posted: Wed Aug 14, 2019 9:34 pm
by thaanstad
It seems that the Megunolink computer software may have a limitation on the amount of data that can be logged to the CSV file. The data is being transferred from the arduino to the computer as I can see in the message log window but the data is not getting logged to the CSV file. First the program I have will log data and will start with having a lot of 0's in the data set. When I turn on the sensors and the data is much larger #'s megunolink will stop logging. The flashing light that indicates logging stops activating as well. I am using the exact same function to print the data in the arduino so I suspect the Megunolink software cannot handle the large csv string I am sending. Can you expand the amount of data that can be logged?
Thanks!!
Re: Extend amount of data that can be logged with Message
Posted: Thu Aug 15, 2019 8:05 am
Can you see the messages in the serial monitor? Do they look right there? Could you paste in some example data so we can try and replicate?
Posted: Tue Aug 27, 2019 8:05 am
For completeness. We have increased the buffer now to 10240 characters so shouldn't be an issue any more.
