TimePlot in Panel
tmccaffr
Fri Oct 25, 2019 4:45 pm
I see that a timplot can be inserted into a Panel. I am unable to send data to the timeplot through the panel interface. Can someone explain how this can be done?
Sat Oct 26, 2019 4:35 am
Hi, it should work exactly the same as the non interface panel version. Just make sure you apply your design and that the interface panel is paired up with the right connection in the connection manager.
