Visualizer just showing values
Joe
Wed Jul 20, 2016 7:23 pm
Is there a visualizer that's just showing incoming serial values. The serial monitor can't be configured. I want just show some bigger digits.
Wed Jul 20, 2016 10:16 pm
Hi Joe, maybe a text box in the interface panel configured to have a large font?
Joe
Sat Jul 23, 2016 11:29 pm
How can I get the serial messages to the text box?
Tue Jul 26, 2016 11:48 pm
Hi Joe, check out this example in our Arduino library.
https://github.com/Megunolink/MLP/tree/ ... /SendToMLP
If you look on line 40 of this file you can see the textbox named "Status" is being set to display "Start".
https://github.com/Megunolink/MLP/blob/ ... dToMLP.ino
The only other thing to remember is that when constructing the interface panel you need to drop in a MLPUIMessageProcessor from the toolbox in the interface designer. This page has more clues for doing that
http://www.megunolink.com/documentation ... ace-panel/
Once you add your text boxes and MLPUIMessageProcessor you should be able to update them from the Arduino.
Hope this helps
Joe
Wed Jul 27, 2016 7:41 pm
OK got it.... But how to show values from a variable? The documentation only shows text strings.
