Plot from record table
ajr349
Thu Jun 23, 2022 9:42 pm
In short, can live XY plot be generated from record table?
I have code that I would like to execute faster on the Arduino side, but serial communication is holding it back because I am printing to a XY plot, 2 time plots, and a record table. There is a lot of unnecessary serial communication happening because all three of the plots could be generated from the data in the record table, however, I would like to see the plots in real time. I have my baud rate as high as possible, so the only solution right now is to cut down in serial communication. Is there anyway to do this?
Thank you!
Fri Jun 24, 2022 2:07 am
Unfortunately this is not possible currently. What baud rate are you using?
