how can I use MLP ino code in PlatformIO? Just tried to compile example RequestSingleParameter.ino. Library is installed correctly but I'm getting these errors
Processing megaatmega2560 (platform: atmelavr; board: megaatmega2560; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (4.1.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 248KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
PACKAGES:
- framework-arduino-avr @ 5.1.0
- toolchain-atmelavr @ 1.70300.191015 (7.3.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- MegunoLink @ 1.41.0
|-- SoftwareSerial @ 1.0
Building in release mode
Compiling .pio\build\megaatmega2560\src\main.cpp.o
Compiling .pio\build\megaatmega2560\lib62a\MegunoLink\ArduinoTimer.cpp.o
Compiling .pio\build\megaatmega2560\lib62a\MegunoLink\BlockParser.cpp.o
Compiling .pio\build\megaatmega2560\lib62a\MegunoLink\CommandDispatcherBase.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:24:57: error: 'Cmd_SetOnTime' was not declared in this scope
SerialCommandHandler.AddCommand(F("numOnTime.Value"), Cmd_SetOnTime);
src\main.cpp:24:57: note: suggested alternative: 'GotOnTime'
GotOnTime
src\main.cpp:25:58: error: 'Cmd_SetOffTime' was not declared in this scope
SerialCommandHandler.AddCommand(F("numOffTime.Value"), Cmd_SetOffTime);
src\main.cpp:25:58: note: suggested alternative: 'GotOffTime'
GotOffTime
src\main.cpp:26:49: error: 'Cmd_ListParameters' was not declared in this scope
SerialCommandHandler.AddCommand(F("ListAll"), Cmd_ListParameters);
src\main.cpp:26:49: note: suggested alternative: 'SpecialParameters'
SpecialParameters
src\main.cpp: In function 'void loop()':
src\main.cpp:41:49: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
digitalWrite(LED_BUILTIN, (uNow - LastBlink < OnTime) ? HIGH : LOW);
src\main.cpp:42:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if ((uNow - LastBlink) > (OnTime + OffTime))
src\main.cpp:51:5: error: 'RequestParameters' was not declared in this scope
RequestParameters();
src\main.cpp:51:5: note: suggested alternative: 'RequestTimer'
RequestTimer
*** [.pio\build\megaatmega2560\src\main.cpp.o] Error 1
