Garage Door Opener Project
Share your projects using MegunoLink Pro here!
Ruger1
Sun Jan 21, 2024 2:59 am
New guy... dumb new guy,
I'm trying to get the garage door project working and am having no luck. My biggest problem is trying to get the sketch to compile . I have tried the "earlier" sketch and then tried a more recent version without success. Biggest problem is the libraries listed in each sketch. aes256 I can't find anywhere. In the more recent sketch, again, it has libraries that I can't seem to find.
Anyone have a little advice? I'd appreciate any suggestions I can get. Appreciate you all!
Tue Jan 23, 2024 7:55 am
Hi, is it this project you are trying to work on?
https://www.megunolink.com/articles/ard ... or-opener/
What hardware are you using?
Ruger1
Wed Jul 10, 2024 11:39 pm
Hello Phil,
This might be a record for time between response! Yes, the link you posted is the one I'm trying to use. I can't get anything to compile. You recommend using the Etherten but it is no longer available. I'm trying to use an Arduino Uno with an Arduino Ethernet Shield (Newest version). Any thoughts would be appreciated. Thanks, Paul
