Problem with new Update 6/5/2017
Posted: Mon Jun 05, 2017 2:28 pm
by dhaffnersr
I am getting this error; no matching function for call to 'XYPlot::SendData(const char [13], int&)'
this is my code snippet; void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
if ((millis() - LastSent) > SendInterval)
LastSent = millis();
int DataValue = analogRead(A0);
MyPlot.SendData("stepperValue", DataValue);
The error is the code in "red," I am setting up my program to monitor a POT attached to pin A0, it was working fine under TimePlot function, but when I updated MegunoLinkPro, now I get this error for XYPlotting?
Need some help :)
Re: Problem with new Update 6/5/2017
Posted: Tue Jun 06, 2017 12:18 am
Hi, it appears you are using our XYPlot class. This requires an X and Y value to be sent across. In your example, you are only sending a single value. I suggest you switch to our TimePlot class which will automatically generate a timestamp for you.
