Trouble with Installer built with Builder
Posted: Mon Aug 20, 2018 2:26 am
by griiker
Hi:
I've built an installer with the instaler builder, but when I try it, I get this message: "A portion of the folder path " is invalid. it is either empty or exceeds the length allowed by the system" I've tried the builder before, and made another installer and it works just fine. so what is wrong here?
griiker
Re: Trouble with Installer built with Builder
Posted: Tue Aug 21, 2018 6:45 am
Hi Griiker, I have emailed you regarding this. Once we know what the issue is ill post a reply here so it can help others.
Posted: Tue Aug 21, 2018 7:46 pm
by griiker
The issue seems to be related with the number of characters in the file path way. (perhaps too many subfolders.
Posted: Tue Aug 21, 2018 11:29 pm
by Paul
Hi Griiker,
I'm wondering if you put a path in the "Destination Folder" field in the "Edit Project Item" dialog?
Normally this isn't needed. When it is blank, the project item will get installed in the main install folder. You can put a folder name here to have it installed in a sub folder. A full path might end up with a subfolder that is too long though.
I'm going to update the UI to make this a bit clearer.
Do you think it might be the problem?
Posted: Wed Aug 22, 2018 4:15 am
by griiker
That solved it! Being a relative newbie, what is patently obvious to more experienced arduinozens is a lot less clear to a beginner like me. often these things are so simple!
thanks
griiker
Posted: Wed Aug 22, 2018 8:55 am
by Paul
We'd like it to be simple for all. Still a little ways to go, but feedback really helps us understand where we need to improve. So thanks for getting in touch!
Please don't hesitate to reach out if you have any more problems.
Have a great day,
