SoftwareSerial on
Posted: Wed Jan 30, 2019 3:13 pm
I had countered an issue regarding on using software serial:
1) using on CommandHandler
2) Message MyCSVMessage for logging
1) when i using button to cmd_set, there is no response i get on monitor. (need to click the button many times then it will appear the response)
2) on logging part, the data can be log, but the name cannot be log either im using rs232_Serial.print("Time"); or rs232_Serial.print(F("Time"));
#include <Time.h>
#include <TimeLib.h>
#include "DS1307.h"
#include <Wire.h>
#include <Adafruit_ADS1015.h>
#include "DHT.h"
#define set_hour clock.hour
#define set_minute clock.minute
#define set_second clock.second
#define set_day clock.dayOfMonth
#define set_month clock.month
#define set_year clock.year+2000
int set_clock_enable = 0;
const String months [] ={"", "Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"};
const String hours [] ={"12", "01", "02", "03", "04", "05", "06", "07", "08", "09", "10", "11", "12", "01", "02", "03", "04", "05", "06", "07", "08", "09", "10", "11"};
char jam[8], minit[8], saat[8];
char masa[20], tarikh[20];
float h, m, s;
float Stab, LowStab[10], lowestStab;
float Field;
float Remote;
float Proximity;
float Humidity;
float Temp;
float Temp_F;
float _FG;
float DistCell = 30; // distance between cell = 30cm
int i,k;
#define DHTPIN 9
#define DHTTYPE DHT11
#include <SoftwareSerial.h>
Adafruit_ADS1115 ads_top(0x48); /* Use this for the 16-bit version */
Adafruit_ADS1115 ads_bottom(0x4B);
DHT dht(DHTPIN, DHTTYPE);
SoftwareSerial rs232_Serial(2, 3); // RX, TX
DS1307 clock;//define a object of DS1307 class
long LastSent;
char field[8], fg[8]; // Buffer big enough for 7-character float
char stab[8], remote[8], proximity[8], _loweststab[8];
int FlagStab;
unsigned long startMillis; //some global variables available anywhere in the program
unsigned long currentMillis;
const unsigned long period = 1000; //the value is a number of milliseconds
Table MyTable;
CommandHandler<> SerialCommandHandler(rs232_Serial);
InterfacePanel MyPanel("", rs232_Serial);
Message MyCSVMessage("Data",rs232_Serial); //"Data" = the taget message channel (remember to select this in megunolink)
TimePlot FGdata("FGplot",rs232_Serial), CPdata("CPplot",rs232_Serial);
void Cmd_SetStabLock(CommandParameter &Parameters)
FlagStab=Parameters.NextParameterAsInteger(FlagStab); //!SetStabLock [1]\r
rs232_Serial.println();
rs232_Serial.print("flag stab: ");
rs232_Serial.println(FlagStab);
void Cmd_GetStabLock(CommandParameter &Parameters)
Parameters.GetSource().print(F("Lock Stab Value = "));
Parameters.GetSource().println(Stab);
dtostrf(Stab, 6, 2, stab); // Leave room for too large numbers!
MyPanel.SetText(F("LockStab"), stab);
void setup(void)
rs232_Serial.begin(9600);
//Serial.println("Hello!");
CPdata.SetTitle("Catode Protection CP Data");
CPdata.SetXlabel("Time");
CPdata.SetYlabel("Voltage (mV)");
FGdata.SetTitle("FG data");
FGdata.SetXlabel("Time");
FGdata.SetYlabel("uV/cm");
FGdata.SetSeriesProperties("FG", Plot::Blue, Plot::Solid, 2, Plot::Square);
CPdata.SetSeriesProperties("Field", Plot::Blue, Plot::Solid, 2, Plot::Square);
CPdata.SetSeriesProperties("Remote", Plot::Red, Plot::Solid, 2, Plot::Square);
CPdata.SetSeriesProperties("Proximity", Plot::Magenta, Plot::Solid, 2, Plot::Square);
ads_top.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV 0.1875mV (default)
ads_bottom.setGain(GAIN_TWOTHIRDS);
SerialCommandHandler.AddCommand(F("GetStabLock"), Cmd_GetStabLock);
SerialCommandHandler.AddCommand(F("SetStabLock"), Cmd_SetStabLock);
SerialCommandHandler.AddCommand(F("SetValues"), Cmd_SetValues);
clock.begin();
MyCSVMessage.Begin();
rs232_Serial.print(",");
rs232_Serial.print("Field");
rs232_Serial.print("Stab");
rs232_Serial.print("Remote");
rs232_Serial.print("Prox");
MyCSVMessage.End();
ads_top.begin();
ads_bottom.begin();
dht.begin();
//clock.begin();
set_clock_enable = 0 ;
startMillis = millis(); //initial start time
i = 0;
void printTime()
String dataString;
String DataString;
clock.getTime();
//date - time
DataString += String(2000+clock.year); DataString +="/"; DataString += String(clock.month); DataString +="/";DataString += String(clock.dayOfMonth);
dataString += String(hours [clock.hour]); dataString +=":";
if(clock.minute <10){dataString +="0";dataString += String(clock.minute); }else{dataString += String(clock.minute);}dataString +=":";
if(clock.second <10){dataString +="0";dataString += String(clock.second); }else{dataString += String(clock.second);}
if(clock.hour>11)dataString +="PM";else dataString +="AM";
DataString.toCharArray(tarikh,20);
dataString.toCharArray(masa,20);
MyPanel.SetText(F("Tarikh"), tarikh);
MyPanel.SetText(F("Masa"), masa);
void Cmd_SetValues(CommandParameter &Parameters){
//Serial.println("update clock");
rs232_Serial.println("update clock");
h = Parameters.NextParameterAsDouble();
m = Parameters.NextParameterAsDouble();
s = Parameters.NextParameterAsDouble();
//clock.fillByYMD(2013,1,19);//Jan 19,2013
clock.fillByHMS(h,m,s);//15:28 30"
//clock.fillDayOfWeek(SAT);//Saturday
clock.setTime();//write time to the RTC chip
void CalculateData(){
/* Be sure to update this value based on the IC and the gain settings! */
//float multiplier = 3.0F; /* ADS1015 @ +/- 6.144V gain (12-bit results) */
float multiplier = 0.1875F; /* ADS1115 @ +/- 6.144V gain (16-bit results) */
//float seconds;
//seconds = (float)millis()/1000;
Stab = float(ads_top.readADC_Differential_0_1())*multiplier;
Field = float(ads_top.readADC_Differential_2_3()*multiplier);
Remote = float(ads_bottom.readADC_Differential_0_1())*multiplier;
Proximity = Stab - Remote;
Temp = dht.readTemperature();
Humidity = dht.readHumidity();
_FG = Field*1000/DistCell;
float hic = dht.computeHeatIndex(Temp, Humidity, false);
void LockStab_(){
if(FlagStab == 1){
rs232_Serial.print(F("*******************************************"));
for(int j=0; j<10; j++){
LowStab[j] = Stab;
k = 0;
int _LowStab = LowStab[k];
if (_LowStab < LowStab[k]){
lowestStab = _LowStab;
else{
lowestStab = LowStab[k];
k++;
dtostrf(lowestStab, 6, 2, _loweststab); // Leave room for too large numbers!
MyPanel.SetText(F("LockStab"), _loweststab);
FlagStab = 0;
void LogData(){
currentMillis = millis(); //get the current "time" (actually the number of milliseconds since the program started)
if (currentMillis - startMillis >= period) //test whether the period has elapsed
//Send data to Interface
CPdata.SendData(F("Field"),Field); // Field = series name, Field = data to plot
//MyPlot.SendData(F("Stab"),Stab); // Stab = series name, Stab = data to plot
CPdata.SendData(F("Remote"),Remote); // Remote = series name, Remote = data to plot
CPdata.SendData(F("Proximity"),Proximity); // Proximity = series name, Proximity = data to plot
FGdata.SendData(F("FG"),_FG); // FG data
dtostrf(Field, 6, 2, field); // Leave room for too large numbers!
dtostrf(Remote, 6, 2, remote); // Leave room for too large numbers!
dtostrf(Proximity, 6, 2, proximity); // Leave room for too large numbers!
dtostrf(_FG, 6, 2, fg);
MyPanel.SetText(F("Field"), field);
MyPanel.SetText(F("Stab"), stab);
MyPanel.SetText(F("Remote"), remote);
MyPanel.SetText(F("Prox"), proximity);
MyPanel.SetText(F("FG"), fg);
String dataString;
clock.getTime();
// date - time
//dataString += String(2000+clock.year); dataString +="/"; dataString += String(clock.month); dataString +="/";dataString += String(clock.dayOfMonth);dataString +=",";
rs232_Serial.print(dataString);
rs232_Serial.print(Field);
rs232_Serial.print(Stab);
rs232_Serial.print(Remote);
rs232_Serial.print(Proximity);
MyCSVMessage.End();
startMillis = currentMillis; //IMPORTANT to save the start time of the current LED state.
void loop(void)
printTime();
CalculateData();
// LockStab_();
LogData();
delay(5);
#include <Time.h>
#include "DS1307.h"
#include <Wire.h>
#include "DHT.h"
float h, m, s;
float Field;
float Remote;
float Proximity;
float Humidity;
float Temp;
float Temp_F;
float _FG;
int i,k;
#define DHTPIN 9
long LastSent;
int FlagStab;
Table MyTable;
void setup(void)
clock.begin();
MyCSVMessage.End();
ads_top.begin();
ads_bottom.begin();
dht.begin();
//clock.begin();
i = 0;
void printTime()
String dataString;
String DataString;
clock.getTime();
//date - time
//float seconds;
void LockStab_(){
if(FlagStab == 1){
LowStab[j] = Stab;
k = 0;
else{
k++;
FlagStab = 0;
void LogData(){
String dataString;
clock.getTime();
// date - time
MyCSVMessage.End();
void loop(void)
printTime();
CalculateData();
// LockStab_();
LogData();
delay(5);
