Hi!
I want to receive serial messages from my ESP32 without having to connect a USB cable.
Im following this tutorial:
https://www.megunolink.com/articles/wir ... with-mdns/
The section called: "mDNS for ESP32 and ESP8266" says that I should add #include "ESPmDNS.h" and some code to be executed upon connecting to a wifi.
I am using PlatformIO on VS Code running Arduino for ESP32, but the library for "ESPmDNS.h" is not available there. I downloaded it directly from: https://raw.githubusercontent.com/espre ... /ESPmDNS.h
Is this the right one?
then I copied the AdvertiseServices code and added a AdvertiseServices("myname"); right after connecting to the wifi, however when compiling it I get this error:
.pio/build/esp32dev/src/main.cpp.o:(.literal._Z17AdvertiseServicesPKc+0x0): undefined reference to `MDNS'
.pio/build/esp32dev/src/main.cpp.o:(.literal._Z17AdvertiseServicesPKc+0x18): undefined reference to `MDNSResponder::begin(char const*)'
.pio/build/esp32dev/src/main.cpp.o:(.literal._Z17AdvertiseServicesPKc+0x1c): undefined reference to `MDNSResponder::addService(char*, char*, unsigned short)'
.pio/build/esp32dev/src/main.cpp.o: In function `AdvertiseServices(char const*)':
/Users/martingarcia/.platformio/packages/framework-arduinoespressif32/cores/esp32/WString.h:85: undefined reference to `MDNSResponder::begin(char const*)'
/Users/martingarcia/.platformio/packages/framework-arduinoespressif32/cores/esp32/WString.h:85: undefined reference to `MDNSResponder::addService(char*, char*, unsigned short)'
collect2: error: ld returned 1 exit status
*** [.pio/build/esp32dev/firmware.elf] Error 1
======================================================== [FAILED] Took 11.18 seconds ========================================================
The terminal process "pio 'run'" terminated with exit code: 1.
any ideas? thanks!
