SerialCommandHandler prints "ovrflw"
Hi, I believe this is because your commands are too long. What command are you sending?
See the section titled "Example Serial Command Handler declarations" here
https://www.megunolink.com/documentatio ... d-handler/
And adjust the maximum command length parameter.
I'm using this
and my longest command is 13 characters long. The only thing is that I send about 3 commands per second over one minute.
Could this be the reason?
I saw some changes in the StreamParser.cpp file where the message is generated but couldn't figure out what causes the overflow.
Joe
I'm using this
CommandHandler<20, 30, 20> SerialCommandHandler(Serial2);Could this be the reason?
Joe
Hi Joe,
Would you mind pasting in a copy of the text from a Monitor window (or send it to our support@megunolink.com email if you prefer to not share it here) please? I'm particularly interested in what's sent just before the first overflow message is printed.
Also check that you have the latest version of our Arduino library (1.34). You can find the library version by opening the "library.properties" file from the MegunoLink library (usually MyDocuments\Arduino\libraries\MegunoLink\library.properties) in a text editor.
The overflow message should only appear if the internal command handler buffer is full when it sees a carriage return (\r). This buffer gathers every character from the ! to the \r so it must be large enough to hold the command and every parameter. Some common reasons to see the overflow message:
Have a nice day
- serial message is too large for the buffer
- missing \r at the end of a command causes a message to join with the next one
Have a nice day
Thanks Joe.
I found an issue that causes the overflow message to be printed whenever the end-of-message (\r) character is received if the buffer had been overflowed before. It doesn't sound like this is the problem you are having though as it wouldn't cause the "Ovrflw" message to be printed all the time; only when a end-of-message character is received.
I put a fix in our Arduino library develop branch if you'd like to try that. Otherwise I will patiently wait for the log
Have a good day
Have a good day
