Help Trying to use TimePlot to compare data samples
Posted: Sun Sep 18, 2022 1:46 am
by ToolAA
I'm new here, and a fairly novice Arduino programmer. However, using the guides, forums and help resources has gotten me pretty far over the past few days. However, I'm at the limit of my experience while trying to solve a problem. I have built a machine use to test part stress failures of 3D printed samples. I typically print 5 or 10 samples of each beam design, then load test them for their failure points. I've been able to successfully collect real time data using the TimePlot function, however I am trying to find a way to record data so that each collected sample, is drawn over top of the existing data. Ideally, each collected sample would be a different color.
Here is an example of what I'm trying to achieve.
- Data Plot Example.jpg (30.97 KiB) Viewed 52544 times
is it possible to record data on the chart using the Fixed Time method, however at each sample, the time would revert to Zero and redraw then next sample data over the previous data sets.
Thank you in advance for your assistance. I'm looking forward to learning more.
Re: Help Trying to use TimePlot to compare data samples
Posted: Sun Sep 18, 2022 2:00 am
Hi, I think you could do this by using the XY Plot (so send your own x values). And you would set it up so that for each plot you use a separate series name. An example for this on the timeplot can be found here
https://github.com/Megunolink/MLP/blob/ ... newave.ino
Note there is a cosine and a sine wave shown independently. XYPlot works the same. So you would need to generate a separate series name for each run you do and then use the same timebase (i.e seconds). Then they should plot on top of each other.
Posted: Sun Sep 18, 2022 2:57 am
by ToolAA
philr wrote: Sun Sep 18, 2022 2:00 am
Thank you. I was playing around with XY Plot just now and decided to do a test with the X axis reading the number of steps counted from my stepper pulse routine. It sort of works. At least I understand how I could use Timebase to achieve a similar result.
- XY Plot Example.jpg (176.22 KiB) Viewed 52537 times
It seems like I'll have to create some sort of "For" statement to count each cycle press and then use that counter to create a series name and possibly alter the individual plotted series colors.
Any idea how I can eliminate that long diagonal line within the plot as it jumps from the high point back to the "Zero" point?
Posted: Sun Sep 18, 2022 7:52 pm
by ToolAA
Well, I'm making steady progress. I've been able to plot multiple readings onto one chart.
- Multi Series Plot.jpg (141.03 KiB) Viewed 52529 times
However, I'm hitting a brick wall with respect to finding a way to create some sort of method to create some sort of incremental series name, and change the plotted line color, during my program loop.
I thought I could create a simple array to input the color variable and increment the series name as just as a simple integer.
int plColor[7]={"Red","Green","Blue","Yellow","Black","Magenta","Cyan"}
for(int s=0; s<7; s++)
plColor[s]
psiPlot.SendData(S, plColor, x/64, pressureValue);
I appreciate any suggestions or hints to point me in the right direction to achieve this chart format output.
Posted: Tue Sep 20, 2022 9:12 am
You might be able to use the pstring library to assembly a string in a char array
http://arduiniana.org/libraries/pstring/
Then use the char array as the series name. I havent tried myself but I think I have done something similar in the past.
Posted: Tue Sep 20, 2022 7:55 pm
by ToolAA
philr wrote: Tue Sep 20, 2022 9:12 am
Then use the char array as the series name. I haven't tried myself, but I think I have done something similar in the past.
Thank you, Phil. I had seen some of your previous references to the pstring library, and I did start looking closer at how it works. My
novicness is of course my biggest limiting factor. Well, I guess we all have to start somewhere.
If you do have an example of using a char array as the series name, I'd love to see it. I'll try to dissect it and see how I can apply the concept to my code. If not, I'll keep plugging along as best that I can. The developers of MegunoLink should know that if someone with such limited experience as me, can get as far as I've already gotten using just the online resources, they must be doing something right.
Posted: Wed Oct 05, 2022 1:28 am
by ToolAA
Phil,
I wanted to circle back and say thanks. It took me a week to teach myself what I needed to do, but Pstring worked perfectly.
- Series Data.jpg (145.41 KiB) Viewed 52480 times
I figured I would share the function here for others to learn from.
// Pressure value function
void pressureData()
{ char buffer[10];
PString series(buffer, sizeof(buffer));
series.print("Test-");
series.print(cycleCount);
currentMillis = millis();
{ pressVal = analogRead(pressureInput);
pressVal = ((pressVal - pressZero) * transMax) / (pressMax - pressZero);
XYPlot psiPlot;
psiPlot.SendData(buffer, plotX/32, pressVal)
MyPanel.SetNumber(F("Seating Force"),pressVal)
startMillis = currentMillis; //IMPORTANT to save the start time of the current state.
Posted: Tue Oct 18, 2022 7:14 am
Great work!
