This is my Arduino code..
#include <MegunoLink.h>
#include <CommandHandler.h>
#include <ArduinoTimer.h>
// Pressure Sensor - Out of Bounds Technology
#include "CommandHandler.h"
#include <TimeLib.h>
#include <Wire.h>
#include <SparkFun_MS5803_I2C.h> // Click here to get the library: http://librarymanager/All#SparkFun_MS5803-14BA
XYPlot Myplot;
MS5803 sensor(ADDRESS_HIGH);
InterfacePanel MyPanel;
CommandHandler<> SerialCommandHandler;
// ***** USER CONROLLED VARIABLES ******
double Pressure_Bias = 1.03; // CHANGE THIS TO CALIBRATE THE PRESSURE SENSOR
double tplBIAS = .35; // Adjust this variable for leek detection sensitvity,(difference peek / max loss)
//***** SYSTEM VARIABLES *****
double PEEK_PRESSURE = 0;
double Pressure_Loss;
double Start_Pressure;
double stability_timer;
double temp_F, temp_c, Base_Pressure;
double pressure_abs = 0;
double pressure_psi = 0;
double Pressure_Average[3];
double timer = 0;
double avg_bar = 0;
double SET_TIMER = 30;
double Set_Time;
double tpLOSS = 0;
double stableDIFF = 0;
double TOTALDIFF = 0;
int start = 0;
int y = 0;
int x = 0;
int Y1 = 1;
int Y2 = 7;
void setup() {
// Start your preferred I2C object
Wire.begin();
//Initialize Serial Monitor
//Retrieve calibration constants for conversion math.
sensor.reset();
sensor.begin();
READ_SETUP_PRESSURE();
SETUP_XYPLOT();
SETUP_DISPLAY();
void loop() {
READ_PRESSURE();
tpLOSS = (PEEK_PRESSURE - avg_bar);
// +++++++++++++UPDATED DISPLAY READINGS ++++++++++
Myplot.SendData("BAR", timer, avg_bar); // Display the graph
MyPanel.SetText(F("DynamicLabel11"), timer);
MyPanel.SetText(F("DynamicLabel2"), avg_bar); // Display BAR pressure
MyPanel.SetText(F("DynamicLabel4"), pressure_psi); // Display PSI pressure
MyPanel.SetText(F("DynamicLabel5"), temp_c);
MyPanel.SetText(F("DynamicLabel6"), temp_F);
MyPanel.SetText(F("DynamicLabel12"), tpLOSS );
if (x == 1){
TOTALDIFF = (tpLOSS - stableDIFF);
MyPanel.SetText(F("DynamicLabel15"), TOTALDIFF);
if (TOTALDIFF <= .03){
MyPanel.SetBackColor(F("DynamicLabel15"), F("Green"));
if (TOTALDIFF > .03){
MyPanel.SetBackColor(F("DynamicLabel15"), F("Orange"));
if (TOTALDIFF > .04){
MyPanel.SetBackColor(F("DynamicLabel15"), F("Red"));
// +++++++ Is there pressure ? ++++++++
if (avg_bar > 1)
if (start == 0){
setTime(0,0,0,0,0,0);
start = 1;
timer = (minute() + (second()*.01)); // start timer
// Is pressure rising? ++++++++++++++
if ((Pressure_Average[0] + .0005) < Pressure_Average[2])
MyPanel.SetBackColor(F("DynamicLabel7"), F("Orange"));
MyPanel.SetBackColor(F("DynamicLabel2"), F("Orange"));
MyPanel.SetBackColor(F("DynamicLabel4"), F("Orange"));
MyPanel.SetText(F("DynamicLabel7"), "PRESSURIZING");
// Is pressure stable? ++++++++++++++
if (Pressure_Average[0] == Pressure_Average[2])
MyPanel.SetBackColor(F("DynamicLabel7"), F("Green"));
MyPanel.SetText(F("DynamicLabel7"), "---PRESSURE STABLE---");
MyPanel.SetBackColor(F("DynamicLabel2"), F("Green")); //
MyPanel.SetBackColor(F("DynamicLabel4"), F("Green"));
stability_timer++;
if (x == 0){
if (stability_timer > .50)
Set_Time = timer;
Base_Pressure = ((sensor.getPressure(ADC_4096)*.001)- Pressure_Bias); // take pressure reading if stable for comparrison.
MyPanel.SetText(F("DynamicLabel9"), Base_Pressure);
stableDIFF = (PEEK_PRESSURE - Base_Pressure);
MyPanel.SetText(F("DynamicLabel10"),stableDIFF);
MyPanel.SetBackColor(F("DynamicLabel13"), F("Green"));
MyPanel.SetText(F("DynamicLabel13"),"TESTING..." );
x = 1;
// Is pressure going down? ++++++++++++++
if ((Pressure_Average[0]- .0005) > Pressure_Average[2])
if (y == 0)
PEEK_PRESSURE = ((sensor.getPressure(ADC_4096)*.001)- Pressure_Bias);
MyPanel.SetText(F("DynamicLabel14"),PEEK_PRESSURE);
y = 1;
if (timer < 1)
MyPanel.SetBackColor(F("DynamicLabel2"), F("yellow"));
MyPanel.SetBackColor(F("DynamicLabel4"), F("Yellow"));
MyPanel.SetBackColor(F("DynamicLabel7"), F("Yellow"));
MyPanel.SetText(F("DynamicLabel7"), "PRESSURE STABILIZING");
else
MyPanel.SetBackColor(F("DynamicLabel2"), F("Red"));
MyPanel.SetBackColor(F("DynamicLabel4"), F("Red"));
MyPanel.SetBackColor(F("DynamicLabel7"), F("Red"));
MyPanel.SetText(F("DynamicLabel7"), "PRESSURE DROPPING");
if (x == 2)
MyPanel.SetText(F("DynamicLabel12"), (Base_Pressure - avg_bar));
// ++++++++++++++++++ IS THERE A LEAK? ++++++++++++++++
if (stableDIFF > 0)
MyPanel.SetBackColor(F("DynamicLabel8"), F("RED"));
MyPanel.SetText(F("DynamicLabel8"), "LEAK DETECTED");
MyPanel.SetBackColor(F("DynamicLabel13"), F("Red"));
MyPanel.SetText(F("DynamicLabel13"),"TESTING FAILED" );
// +++++++++++++++++++++++ FUNCTIONS +++++++++++++++++++++
void SETUP_DISPLAY()
MyPanel.SetBackColor(F("DynamicLabel5"), F("Control"));
// MyPanel.SetText(F("DynamicLabel7"), "");
MyPanel.SetBackColor(F("DynamicLabel7"), F("White"));
MyPanel.SetBackColor(F("DynamicLabel8"), F("White"));
MyPanel.SetText(F("DynamicLabel8"), "");
MyPanel.SetBackColor(F("DynamicLabel2"), F("White"));
MyPanel.SetText(F("DynamicLabel12"), 0.00);
MyPanel.SetBackColor(F("DynamicLabel4"), F("White"));
MyPanel.SetText(F("DynamicLabel9"), 0.00);
MyPanel.SetText(F("DynamicLabel10"),0.00);
MyPanel.SetBackColor(F("DynamicLabel11"), F("Control"));
MyPanel.SetText(F("DynamicLabel11"), "");
MyPanel.SetBackColor(F("DynamicLabel13"), F("Cyan"));
MyPanel.SetText(F("DynamicLabel13"),"WAITING" );
MyPanel.SetBackColor(F("DynamicLabel15"), F("Control"));
MyPanel.SetText(F("DynamicLabel15"), 0.00);
void SETUP_XYPLOT()
Myplot.Clear("BAR");
Myplot.SetTitle("P-TESTER - V2");
Myplot.SetXLabel("MINUTES");
Myplot.SetYLabel("BAR");
Myplot.SetSeriesProperties("BAR", Plot::Red, Plot::Solid, 2,Plot::NoMarker);
Myplot.SetYRange(Y1,Y2);
Myplot.SetY2Label("BAR");
Myplot.SetXRange(0,SET_TIMER);
double READ_PRESSURE()
// ++++++++++++PUT READINGS INTO AN ARRAY+++++++++++
for (byte i = 0; i < 3; i++)
Pressure_Average[i] = ((sensor.getPressure(ADC_4096)*.001) - Pressure_Bias);
if (Pressure_Average[i] <= 0 )
Pressure_Average[i] = 0;
delay(300);
// +++++++ Average the Pressure Readings ++++++++++++
avg_bar = ((Pressure_Average[0] + Pressure_Average[1] + Pressure_Average[2])/3);
// +++++++ Convert to PSI ++++++++++++
pressure_psi = (avg_bar * 14.5038);
// +++++++ GET TEMP READINGS ++++++++++++
temp_c = sensor.getTemperature(CELSIUS, ADC_512);
temp_F = sensor.getTemperature(FAHRENHEIT, ADC_512);
double READ_SETUP_PRESSURE()
Start_Pressure = ((sensor.getPressure(ADC_4096)*.001) - Pressure_Bias);
This is the compile error....
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\Greg\\Documents\\LTSketchbook\\libraries\\MLP-master" "-IC:\\Users\\Greg\\Documents\\LTSketchbook\\libraries\\Time-master" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Users\\Greg\\Documents\\LTSketchbook\\libraries\\SparkFun_MS5803-14BA_Pressure_Sensor\\src" "C:\\Users\\Greg\\AppData\\Local\\Temp\\arduino_build_543485\\sketch\\P-TESTER-V2rev2.03.ino.cpp" -o "C:\\Users\\Greg\\AppData\\Local\\Temp\\arduino_build_543485\\sketch\\P-TESTER-V2rev2.03.ino.cpp.o"
In file included from C:\Users\Greg\Documents\LTSketchbook\libraries\MLP-master/MegunoLink.h:6:0,
from C:\Users\Greg\Desktop\P-TESTER-V2\P_TESTER-V2.2\FIRMWARE 2.03\P-TESTER-V2rev2.03\P-TESTER-V2rev2.03.ino:1:
C:\Users\Greg\Documents\LTSketchbook\libraries\MLP-master/utility/TimePlot.h:90:50: error: 'tm' has not been declared
void SetCursorPosition(const char* SeriesName, tm &Time);
C:\Users\Greg\Documents\LTSketchbook\libraries\MLP-master/utility/TimePlot.h:91:65: error: 'tm' has not been declared
void SetCursorPosition(const __FlashStringHelper* SeriesName, tm& Time);
Using library MLP-master at version 1.30 in folder: C:\Users\Greg\Documents\LTSketchbook\libraries\MLP-master
Using library Time-master at version 1.5 in folder: C:\Users\Greg\Documents\LTSketchbook\libraries\Time-master
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library SparkFun_MS5803-14BA_Pressure_Sensor at version 1.1.2 in folder: C:\Users\Greg\Documents\LTSketchbook\libraries\SparkFun_MS5803-14BA_Pressure_Sensor
exit status 1
Error compiling for board Arduino Pro or Pro Mini.
