sending values to Gauge
Posted: Sun Jan 29, 2023 12:01 pm
by ElectricRay1981
When I try to send data to the Gauge I keep having the message AddCommand: full. When I directly send a number in the Arduino sketch it works fine but when I attach a variable it doesn't work. Does anybody knows what I am doing wrong?
void loop() {
  SerialCmds.Process();                                             //Monitor serial commands
  if (timeOut(250)) {  // 4 Hz update frequency
    cli(); //stop interrupts
    prevPulseUsCopy = prevPulseUs;
    pulseUsCopy = pulseUs;
    sei(); //allow interrupts
    pulsePeriod = pulseUsCopy - prevPulseUsCopy;
    if (pulsePeriod) rpm = 20 + slotUs / pulsePeriod ;
    Serial.println(rpm);
    SerialCmds.AddCommand(F("GetSpeed"),Cmd_SendSpeedRightMotor);
void Cmd_SendSpeedRightMotor(CommandParameter& p)
  // Set control value
  MyPanel.SetNumber(F("IPGauge2"), rpm);
Above the part of my code that should send the value rpm to Megunolink. rpm is a integer. I hope someone knows what I am doing wrong.
Re: sending values to Gauge
Posted: Wed Feb 01, 2023 8:11 am
Hi, can you post the rest of your program?
You should only add the command handler once in the setup part of your program. Not in the loop part.
Posted: Sun Feb 05, 2023 2:47 pm
by ElectricRay1981
Sorry for the late reply I did not receive a notification (I found the checkbox now). I was able to make it work over serial connection but when creating a WiFi connection I'm unable to send data to the gauge wireless.
#include <TCPCommandHandler.h>
#include <CommandHandler.h>
#include "CommandProcessor.h"
#include <MegunoLink.h>
#include <WiFi.h>
const char *SSID = "My SSID";
const char *WiFiPassword = "My PSWD";
const char *Host = "Desktop IP";
const unsigned Port = 11000;
WiFiClient Client;
CommandHandler<> SerialCmds;
void ConnectToWiFi()
  WiFi.mode(WIFI_STA);
  WiFi.begin(SSID, WiFiPassword);
  Serial.print("Connecting to "); Serial.println(SSID);
  uint8_t i = 0;
  while (WiFi.status() != WL_CONNECTED)
    Serial.print('.');
    delay(500);
    if ((++i % 16) == 0)
      Serial.println(F(" still trying to connect"));
  Serial.print(F("Connected. My IP address is: "));
  Serial.println(WiFi.localIP());
WiFiClient *GetClient()
  if (!Client.connected() && Client.connect(Host, Port))
    return &Client;
  return Client.connected() ? &Client : NULL;
void SendMeasurement(unsigned Value)
  WiFiClient *pClient = GetClient();
  if (pClient != NULL)
      MyPanel.SetNumber(F("RightSpeedGauge"), 1);
  else
    Serial.println("TCP Connection failed");
  ConnectToWiFi();
  unsigned Measurement = 10;
  SendMeasurement(Measurement);
  delay(1000);
As you can see I tried to use the example from the documention but appearently I use it the wrong way. Not sure what to do, I was hoping that the command
would send a value of 1 to the gauge over WiFi connection.
When I ping the ESP32 I get a response so it is connected to the network. How should I fix this?
Thanks in advance
