MLP and PlatformIO errors
Posted: Sat Mar 11, 2023 9:25 pm
how can I use MLP ino code in PlatformIO? Just tried to compile example RequestSingleParameter.ino. Library is installed correctly but I'm getting these errors
Maybe someone else already solved the problems
Processing megaatmega2560 (platform: atmelavr; board: megaatmega2560; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (4.1.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 248KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
PACKAGES:
- framework-arduino-avr @ 5.1.0
- toolchain-atmelavr @ 1.70300.191015 (7.3.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 6 compatible libraries
Scanning dependencies...
Dependency Graph
|-- MegunoLink @ 1.41.0
|-- SoftwareSerial @ 1.0
Building in release mode
Compiling .pio\build\megaatmega2560\src\main.cpp.o
Compiling .pio\build\megaatmega2560\lib62a\MegunoLink\ArduinoTimer.cpp.o
Compiling .pio\build\megaatmega2560\lib62a\MegunoLink\BlockParser.cpp.o
Compiling .pio\build\megaatmega2560\lib62a\MegunoLink\CommandDispatcherBase.cpp.o
src\main.cpp: In function 'void setup()':
src\main.cpp:24:57: error: 'Cmd_SetOnTime' was not declared in this scope
SerialCommandHandler.AddCommand(F("numOnTime.Value"), Cmd_SetOnTime);
src\main.cpp:24:57: note: suggested alternative: 'GotOnTime'
GotOnTime
src\main.cpp:25:58: error: 'Cmd_SetOffTime' was not declared in this scope
SerialCommandHandler.AddCommand(F("numOffTime.Value"), Cmd_SetOffTime);
src\main.cpp:25:58: note: suggested alternative: 'GotOffTime'
GotOffTime
src\main.cpp:26:49: error: 'Cmd_ListParameters' was not declared in this scope
SerialCommandHandler.AddCommand(F("ListAll"), Cmd_ListParameters);
src\main.cpp:26:49: note: suggested alternative: 'SpecialParameters'
SpecialParameters
src\main.cpp: In function 'void loop()':
src\main.cpp:41:49: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
digitalWrite(LED_BUILTIN, (uNow - LastBlink < OnTime) ? HIGH : LOW);
src\main.cpp:42:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if ((uNow - LastBlink) > (OnTime + OffTime))
src\main.cpp:51:5: error: 'RequestParameters' was not declared in this scope
RequestParameters();
src\main.cpp:51:5: note: suggested alternative: 'RequestTimer'
RequestTimer
*** [.pio\build\megaatmega2560\src\main.cpp.o] Error 1
