Serial communication Stops
Posted: Wed Aug 02, 2023 4:20 am
I have an interface panel that just stops receiving data. To get it to restart, I have to use Connection Manager to disconnect and reconnect to get it going again. I have the baud rate running at 19,200 and am sending data to 3 time plot lines, 4 gauges and about 6 dynamic labels. At the same time I am using a USB to CAN adapter to talk to a Sevcon motor controller. So, that said, should I use a different combination of baud rates, if so what would be optimum? Is there a way to get MegunoLink automatically reconnect when the connection drops? It would be OK to have a little data loss, but having a full disconnect kind of blows the testing.
The project is a Dynomometor interface using an Arduino Uno. Sensors pickup and send output to MegunoLink for RPM, Torque, Temperature, Volts, Current, Hp. The Arduion seems to keep up with it.
