Problem with UDP and MegunoLink Host Builder
tabbiati
Sun Dec 31, 2017 12:27 pm
i have a problem with MegunoLink Host Builder and my project that use UDP; in MegunoLink al working ok but when i create and install package from it is impossible use connect button (like it is not working).
Any suggestion?
rsfoto
Sun Dec 31, 2017 11:59 pm
Did you connect the hardware to the PC you want to start ?
tabbiati
Mon Jan 01, 2018 10:29 am
thanks for reply; yes the problem there is only with packet build with Host Builder and all is ok in MegunoLink.
Mon Jan 01, 2018 8:04 pm
Yep there is a bug. Should be fixed in the next update. Hopefully today or tomorrow.
Tue Jan 02, 2018 2:48 am
Connecting should now work.
tabbiati
Tue Jan 02, 2018 2:14 pm
Hi Philip,
Problem with UDP now is solved as You says; adjust IP address would be very usefull but for now i don't use it.
Now i have another problem: series propriety in chart, when i build a package with Host Builder aren't the same that i have set in MegunoLink and if i set in application setting is lost between two session of use; this also i flag autosave in builder or save button.
Sorry for my poor English
Sat Jan 06, 2018 11:07 pm
I'll post my email here too so everyone knows a solution for this. There is indeed a bug which will be fixed going forward but a better solution is to include the style information in the plotting message.
Hi Tullio, I tested it here and you're right it does seem to default to the same style. I suggest you modify your plotting messages to include the series properties you want.
For example
{TIMEPLOT|DATA|Cosinewave:bo-3|T|0.59}
{TIMEPLOT|DATA|Sinewave:ro-3|T|-0.36}
notice the ":bo-3" and ":ro-3"
These set the series to be blue (b) and red (r) with dashed line and circle markers.
See this page for the different styles etc
https://www.megunolink.com/documentatio ... reference/
Our Arduino library makes this even easier to build the right messages. This page has the detail
