I am thinking, now evaluating, in using MegunoLink for my projects. The problem is that I am using can bus data and a DUE board. It seems this library and DUE are incompatible. The use of command handler works properly but not the variables. This line in blink2 demo program : " SerialCommandHandler.AddVariable(F("OnTime"), OnTime);" doesn't work when compiling for DUE device.
The proble after compilation is in bool AddVariable(const __FlashStringHelper *pName, uint8_t &rVariable);
Please do you now is there is any solution?
thank you very much in advance.
MagunoLink and DUE
Hi, it looks like for the due an "int" is not the same as a "int16_t" which it is for the normal Arduinos.
I think you should be able to change
int OnTime = 10; // Amount of time the LED remains on [milliseconds]
int OffTime = 100; // Amount of time the LED remains off [milliseconds]
to
int16_t OnTime = 10; // Amount of time the LED remains on [milliseconds]
int16_t OffTime = 100; // Amount of time the LED remains off [milliseconds]
and it should work again.
to
eragonsmith
Thank you very much philr. Now it compiles. I have not my arduino due boards as I am moving. Sure it will work as it compiles now.
