Hi:
I've built an installer with the instaler builder, but when I try it, I get this message: "A portion of the folder path " is invalid. it is either empty or exceeds the length allowed by the system" I've tried the builder before, and made another installer and it works just fine. so what is wrong here?
griiker
Trouble with Installer built with Builder
Hi Griiker,
I'm wondering if you put a path in the "Destination Folder" field in the "Edit Project Item" dialog?
Normally this isn't needed. When it is blank, the project item will get installed in the main install folder. You can put a folder name here to have it installed in a sub folder. A full path might end up with a subfolder that is too long though.
I'm going to update the UI to make this a bit clearer.
Do you think it might be the problem?
We'd like it to be simple for all. Still a little ways to go, but feedback really helps us understand where we need to improve. So thanks for getting in touch!
Please don't hesitate to reach out if you have any more problems.
Have a great day,
Have a great day,
