Hi all,
I am trying to call a function that is also one of my serial command functions. I thought this could be an efficient way to reuse a serial command function's code.
For example if I have the following function, what syntax is required to call this function?
void Cmd_Clutch(CommandParameter &Parameters){
"CODE"
Thanks,
John
Calling a serial command function
JohnPalmerGT
Hi, I will just be running the code inside the function.
JohnPalmerGT
That is a very simple logical solution, thanks.
