ElectricRay1981
Sun Jan 29, 2023 12:01 pm
When I try to send data to the Gauge I keep having the message
AddCommand: full. When I directly send a number in the Arduino sketch it works fine but when I attach a variable it doesn't work. Does anybody knows what I am doing wrong?
void loop() {
SerialCmds.Process(); //Monitor serial commands
if (timeOut(250)) { // 4 Hz update frequency
cli(); //stop interrupts
prevPulseUsCopy = prevPulseUs;
pulseUsCopy = pulseUs;
sei(); //allow interrupts
pulsePeriod = pulseUsCopy - prevPulseUsCopy;
if (pulsePeriod) rpm = 20 + slotUs / pulsePeriod ;
Serial.println(rpm);
SerialCmds.AddCommand(F("GetSpeed"),Cmd_SendSpeedRightMotor);
void Cmd_SendSpeedRightMotor(CommandParameter& p)
// Set control value
MyPanel.SetNumber(F("IPGauge2"), rpm);
Above the part of my code that should send the value rpm to Megunolink. rpm is a integer. I hope someone knows what I am doing wrong.
Wed Feb 01, 2023 8:11 am
Hi, can you post the rest of your program?
You should only add the command handler once in the setup part of your program. Not in the loop part.
ElectricRay1981
Sun Feb 05, 2023 2:47 pm
Sorry for the late reply I did not receive a notification (I found the checkbox now). I was able to make it work over serial connection but when creating a WiFi connection I'm unable to send data to the gauge wireless.
#include <TCPCommandHandler.h>
#include <CommandHandler.h>
#include "CommandProcessor.h"
#include <MegunoLink.h>
#include <WiFi.h>
const char *SSID = "My SSID";
const char *WiFiPassword = "My PSWD";
const char *Host = "Desktop IP";
const unsigned Port = 11000;
WiFiClient Client;
CommandHandler<> SerialCmds;
void ConnectToWiFi()
WiFi.mode(WIFI_STA);
WiFi.begin(SSID, WiFiPassword);
Serial.print("Connecting to "); Serial.println(SSID);
uint8_t i = 0;
while (WiFi.status() != WL_CONNECTED)
Serial.print('.');
delay(500);
if ((++i % 16) == 0)
Serial.println(F(" still trying to connect"));
Serial.print(F("Connected. My IP address is: "));
Serial.println(WiFi.localIP());
WiFiClient *GetClient()
if (!Client.connected() && Client.connect(Host, Port))
return &Client;
return Client.connected() ? &Client : NULL;
void SendMeasurement(unsigned Value)
WiFiClient *pClient = GetClient();
if (pClient != NULL)
MyPanel.SetNumber(F("RightSpeedGauge"), 1);
else
Serial.println("TCP Connection failed");
ConnectToWiFi();
unsigned Measurement = 10;
SendMeasurement(Measurement);
delay(1000);
As you can see I tried to use the example from the documention but appearently I use it the wrong way. Not sure what to do, I was hoping that the command
would send a value of 1 to the gauge over WiFi connection.
When I ping the ESP32 I get a response so it is connected to the network. How should I fix this?
Thanks in advance
