help with a push button for Arduino
Hi, check out these links for an example. You need to configure the interface panel button to send the correctly formatted command message which will trigger the corresponding code.
https://github.com/Megunolink/MLP/blob/ ... meters.ino
http://www.megunolink.com/documentation ... d-handler/
http://www.megunolink.com/getting-start ... ace-panel/
