How can I change the TrackBar into the property of the Progression Bar? I would like to use the Trackbar to receive values from my sketch and reflect the number in text box.
Thanks in advance
TrackBar Transformation
Hi, similar to before what are the messages you have sent from your arduino? Can you capture them in the monitor. They should look like:
{UI|SET|MyTrackbar.Value=10}
{UI|SET|MyTrackbar.Value=20}
{UI|SET|MyTrackbar.Value=30}
{UI|SET|MyTrackbar.Value=40}
{UI|SET|MyTrackbar.Value=50}
Where your trackbar is called "MyTrackbar".
