Support to speak message?
alains
Fri Sep 20, 2019 6:02 pm
Do you still support the following in the new version? I do not find any information on your documentation.
mySerial.println("{MESSAGE|SPEAK+DATA|End of tests of "+String(maxCycles)+ "Cycles for Temperatures range: \n"+String(StartTemp) + " degree C "+"}");
Sat Sep 21, 2019 12:05 am
Hi Alain, I tried to reply to your email but it says its getting rejected. Anyway ill copy the reply here.
I tried your first example and it worked fine. I did this:
Serial.println("{TABLE|SET|Deg.C|"+String(millis())+"}");
Which printed the millis timer to the table. Seemed to work.
As for your second question in the email you had only DATA not SPEAK+DATA
I tried this and it worked fine on my computer.
mySerial.println("{MESSAGE|SPEAK+DATA|Parameters:"+ myParams + "}");
In short we haven't changed anything that should have broken that functionality. Confirm in your serial monitor you are getting the messages correctly. Raw messages should look like this
https://www.megunolink.com/documentatio ... reference/
alains
Sat Sep 21, 2019 2:57 am
Thanks Phil, just to make sure: In order to have the {MESSAGE|SPEAK+DATA... working I need a message monitor ,even that there is no printed data on it, just spoken data?
Sun Sep 22, 2019 6:16 pm
Yes that is correct. That establishes a listener for that type of message. Without it they don't get processed by anything.
