Can't install multiple build programs
Support forum for Builder.
Buryszek
Wed Nov 18, 2020 2:50 pm
Hi there,
I have the following issue:
I have 2 programs I made in Meguno Link and I built an intaller for both in Host Builder.
When I try to install the 2nd program, it deletes the first one, even if I change the installation directory.
Is there some way to get both programs installed on the same system?
I don't want to uninstall & install the program each time that I have to switch.
Kind Regards,
Pascal
Sun Dec 06, 2020 6:40 am
Hi, did you use the same project file with the same product id for each? If so it would overwrite one with the other. You need to create completely new project files for each.
Any luck with this?
