I was wondering if anyone has tried to send table data over bluetooth. one of the projects I am making would benefit from this feature however i have so far been unable to acheive this goal.
I am currently just trying to use the example "BasicRecordTable" over Bluetooth. I have confirmed Bluetooth works (added a button which worked, then removed it from the code and interface) and also confirmed the table date fills in if i use a USB connection however i can't work out why its not working over bluetooth.
I was just curious if anyone else has tried this or am i missing something obvious?
Thank you for the help in advance
Input Data in Table over Bluetooth
Hi, did you get this going? I suspect you just need to make sure you point the table object to use the bluetooth serial rather than the default serial port.
For example if your bluetooth serial port is declared as:
BluetoothSerial SerialBT;
Then you would simply point the table library to use that connection. Like this:
RecordTable MyTable(SerialBT);
