new compiling errors
GOHO
Mon Nov 22, 2021 7:22 pm
Hi, earlier this year i built a project using my arduino, pressure sensor and the megunolink to measure and monitor a pressurized tank and it worked great. Recently i built another pressure tester and i tried to compile the exact same code into the sensor and it errors from the megunolink library. Has something changed in the driver that would cause a sketch from say march to not compile?
GOHO
Mon Nov 22, 2021 7:37 pm
arduino error 1.png (102.37 KiB) Viewed 58296 times
arduino error 2.png (113.84 KiB) Viewed 58296 times
this sketch always compiled without issue, now it errors.
Tue Nov 23, 2021 11:25 pm
Hi Goho,
I noticed you also have a library called "Time-master" in the build output. My guess is that there is a conflict with that library and the built-in "time.h" library we are using. That could happen if the "Time-master" library has a file named "time.h" too (it could override the system one).
To resolve, you could rename time.h in the time-master library to something else, propagating that change to any #includes in other files in the time-master library. I found a few Arduino time libraries so I'm not sure which one you are using. If you could post a link to it we might be able to figure out a different solution.
It looks like support for sending time values with our plotting library was made in January this year. So likely is the problem.
Have a good day
GOHO
Wed Nov 24, 2021 5:08 pm
thanks, ill check that but it didn't error before so im thinking maybe an updated library was the issue.
I have a pressure tester that is working right now using that exact code but now it wont compile....
GOHO
Wed Nov 24, 2021 5:13 pm
thinking what might have changed, the only thing i updated since i last compiled this sketch was Megunolink. i have not updated the Arduino IDE or and library so the issue must be in an update from Megunolink.
GOHO
Thu Nov 25, 2021 6:01 pm
i updated the Time library and it compiles ok. Problem solved!
Wed Dec 01, 2021 2:04 am
The new 'error' was definitely my fault as I added a new feature to our Arduino library (to include time values when sending data to our time-plot visualizer). Glad you were able to resolve the conflict with an update to the time library. Thanks for letting us know!
Have a great day
