I’ve got a reproducible glitch: without a timestamp the value is fine, add a timestamp and the Y value shows up as a hex.
// OK → numeric shown correctly (e.g., 25)
gT1.SendData("temp1", (float)t1_C);
// NOT OK → arrives as hex
gT1.SendData("temp1", ts.c_str(), (float)t1_C);
Targeting this per docs:
SendData(SeriesName, TimeStamp, YValue, SeriesProperties — optional)
Environment
Teensy 4.1
ts is a std::string (ASCII, no NULs), lifetime valid
Series name is a RAM string (no F() macro)
Tried
Explicit casts:
gT1.SendData("temp1", ts.c_str(), static_cast<float>(t1_C));
gT1.SendData("temp1", ts.c_str(), static_cast<double>(t1_C));
Ask
For the timestamped call, does YValue need to be a specific type?
Is there an overload-resolution trap where (const char*, float) binds to a variant that treats the float as raw bytes?
What timestamp format does this overload expect (epoch ms, ISO-8601, etc.) to keep YValue parsed as numeric?
What’s the exact prototype I should be hitting for (SeriesName, TimeStamp, YValue)?
Thanks for your help!
SendData hex number
Hi Oriol,
I haven't had a chance to reproduce yet, but my guess is the compiler is matching this overload:
In otherwords, it is treating the time string as the YData and construct an RGB colour from your float / double argument. Colours are sent in hex, hence the result you see. I should have marked the `RGBColor(uint32_t)` constructor as explicit so this didn't happen. Sorry.
A couple of suggestions:
* use one of the SendData overloads that use the tm structure (https://en.cppreference.com/w/c/chrono/tm) as an argument, if you have time in this format,
* build the message manually, as you already demonstrate successfully. MegunoLink will accept dates as a double or integer (treated as seconds since the Unix time epoch) or in these formats:
Kind regards
template<typename TSeries, typename TYData>
void SendData(TSeries seriesName, TYData yValue, const RGBColor& Color, LineStyle Line = MissingLineStyle, uint8_t uLineWidth = 0, MarkerStyle Marker = MissingMarkerStyle, Axis ax = MissingAxis)
SendSeriesHeader_Data(seriesName, false);
SendDataCore(nullptr, nullptr, yValue, Red, Color, true, Line, uLineWidth, Marker, ax);
}A couple of suggestions:
private static readonly string[] m_astrDateTimeFormats = new string[]
"yyyy-M-d H:m:s",
"yyyy-M-d H:m",
"yyyy-M-d H:m:s.FFFF",
"yyyy-M-d",
"H:m:s",
"H:m",
"H:m:s.FFFF"
};Paul.
