Sorry if this has been asked for already, or if it is already implemented but I couldn't find it.
What I would really like as a feature is a popup style message box.
Uses could include:
- More visible warning information (e.g. you have a setup with a stepper motor and you want to send a message to the panel once the stepper has reached position. A window could pop up informing you)
- 2-click acknowledge (e.g. Stepper example again. You can set your speed using Megunolink and a set button, but what happens if you accidentally change your settings and can't remember the old ones? A pop-up warning box could solve the issue by informing you "Warning: Do you really want to change your settings (Proceed / Cancel)
- Version info or about information (e.g. a small picture of ? and once you click it, it gets the version info that has been previously stored in Arduino memory)
- Loads of other stuff
So maybe, if it is not too hard to implement and others would like a feature like this as well, it could be a possibility for future implementation
Kind regards
Sven
