When Will Arduino 1.7.6 Be Supported?
hawkinsrl
Thu Aug 27, 2015 2:39 pm
Hi:
When I go to Tools:Setup Arduino Integration menu, I see a message under the Arduino Upload Monitor that v1.7.6 is not supported. What's the timescale for this support?
Thanks.
Tue Sep 08, 2015 11:35 pm
Hi, I just tested the upload monitor with this version and it worked fine. The installation tool needs to be updated to make it work. In the mean time you can manually copy the avrdude files over to get it working. Simply copy the files from the zip file attached into
\%your-arduino-folder%\hardware\tools\avr\bin
If its the MegunoLink library you're after grab it from github and add it to the ide using the toolbars in the application.
https://github.com/Megunolink/MLP
MegunoLink avrdude.zip
for arduino upload monitor support
(182.3 KiB) Downloaded 1371 times
