Edit series property
Pelle8879
Mon Dec 16, 2019 6:58 pm
I can not change the series property. when changing it goes back after a short while. Why?
It always goes back to line with symbol.
Fri Jan 03, 2020 11:40 pm
Hi Pelle, its probably because you are setting the line properties from the arduino end as well? This will overwrite the local changes.
Pelle8879
Sun Jan 05, 2020 3:50 pm
No I am not setting any properties.
MyPlot1.SendData(F("UppAcktemp"), UAckT,"Grader");
MyPlot1.SendData(F("MidAcktemp"), MAckT,"Grader");
Is there any wrong with above?
Should i set properties maybe?
Mon Jan 27, 2020 2:32 am
Are you clearing the plots? That would reset them to the defaults when the next data comes in. Maybe setting the properties in the plot message solves your problem?
